Removing BPV
Removing BPV
I'm new to the mini scene but I consider myself pretty good with cars in general.
I took it apart yesterday to try and do the vacuum mod. My BPV looks like it could be the original with 130k on it. Only reason I think that is because of the big rubber hose at the bottom. Has factory style clamps on it and the rubber looks dry rotted and cracked.
Do I need to cut these clamps off?
This morning I went out and changed everything. The T fitting that the boost gauge was screwed onto had no thread tape and it was loose. I removed that T and put it on the left side of the intake manifold. I then put a T at the FPR and ran a line to the BPV also.
Now I'm reading 20+ vacuum and 10 boost. It should put out more than 10psi though, right? The gauge is an autometer. Can't remember the model of it though. If my intercooler couplers are leaking, that's where I may be loosing boost? Any tricks to get them tighter?
Without pulleys it looks like you are right on the money.
https://www.northamericanmotoring.co...boost-psi.html
Drivetrain Bad BPV...replace with stock BPV or DT BPV??
IQRaceworks
08-21-2011 03:37 PM
ekim
08-20-2006 05:32 AM
tattman23
12-23-2005 10:36 AM
