Cylinder 3 misfire
Misfire no compression
The other day on my way to work then car suddenly lost a little power, ran rough and engine light started flashing. Once at work I hooked the scanner up and got a code for the rear o2 and multiple misfire. I pulled each plug wire while it was running and there didn't seem to be any change in the way it idled.
Installed new o2 sensor and that code is gone now. Got a different coil and wires and now I have misfire cylinder 3. I swapped 3/4 wires and plugs. Swapped cylinder 3/4 fuel injectors also. Everything I do, it keeps Comming up cylinder 3. I'm going to go grab the cheapest plugs I can just to test it. I'm worried it's something allot more serious.
Usually, if it is a burned valve, you'll see a small chunk missing from the valve head.
If you truly have NO compression at all in that cylinder, it will be large chunk missing.
Check the top of the piston for damage - the broken chunk may have scratched/scored/dented it. If it's not too deep it's not a big deal in my opinion.
Worst case there's a hole in the piston - that's a big deal.
Can you stick to one thread, please? !
Please understand this: The result you found, is not the problem. The valves most likely burned, due to a lean running engine, which may have been and injector, the use of regular (lower octane fuel, leaks in the intake system, valve lash too tight (really only thing here is loose valve guides. Make sure to replace them and check the other guides and valves for wear also), or possibly mis tuned. This cylinder got really hot to burn the valves this badly!
Based on the one photo you posted, it looks like the left hand exhaust valve in Cylinder 4 is also starting to burn, based on the discoloration around the rim of it. I had to swap a cylinder head on my R50 because it had low compression in 2 and slightly low compression in 3.
I'm including a photo of my cylinder head for comparison.
My R50 cylinder head with burned valves in cylinder 2 and 3.
2003minicooper
05-03-2012 03:57 PM
OctaneGuy
08-24-2007 11:28 PM
