Tpms r53
Old 09-01-2018 | 07:34 PM
Tombstone's Avatar
Tombstone
Tpms r53
What is the most common problem with TPMS that causes the light to stay on; my R53 has the wheel sensor hubs ( hub or sensor wire) ?
Old 09-02-2018 | 02:58 AM
DamnCampers's Avatar
DamnCampers
What have you already tried? Is there any other lights that are on? Is there a change in how the car handles?
I would start with checking your tire pressure. Adjust as needed. The next time you put the key in, before you start the engine press the button just below the e-brake. Start the car and drive it a bit. The light should go out if its just the tire pressure that is off.
Old 09-03-2018 | 08:43 AM
Tombstone's Avatar
Tombstone
Tpms
Checked all tire pressures, reset button next to e-brake and drove around for appx 20 minutes ,light still on .Going to isolate (unplug one @ a time or ohm out ) wheel sensors to determine which wheel. Thanks...
Old 09-03-2018 | 03:34 PM
DamnCampers
Are there any codes being thrown by the car? If you are going to check each sensor check your brakes as well as there are wear sensors on those as well.
Old 09-03-2018 | 03:50 PM
phh06's Avatar
phh06
Check wiring going to reset switch in center console. I had same problem and this finally fixed.
Old 09-03-2018 | 05:54 PM
Tombstone's Avatar
Tombstone
Tpms
No codes and brand new factory JCW brakes and rotors ; brakes sensors were cleaned up and re-installed...
Old 09-03-2018 | 05:57 PM
Tombstone's Avatar
Tombstone
Tpms
Thanks for the tip on console wiring to reset switch, I will run the wiring out and let you know.Regards...
Old 09-05-2018 | 12:53 PM
Tombstone's Avatar
Tombstone
Located the problem , had a bad ABS /TPMS sensor ...
Matt Moore
Tires, Wheels, & Brakes
07-27-2012 12:19 PM
Swank1975
MINI5280
06-18-2012 05:39 PM
oilyrover
10-30-2011 10:52 AM
ckdunn
03-21-2011 10:40 PM
owl
08-14-2009 02:07 PM
