Fog lights & driving lights...
I know everyone's seen the Italian Job by now. What I'm wondering is if anyone has figured out what wires to disconnect in order to let the fog lights remain on when you turn on your brights... hence you can have your driving lights and fog lights on at the same time.
Yes, I know its illegal... but I can take my chances. I already run without a front plate. :smile: :smile:
My original look into this very dilemma a while back kinda came up with nothing, mainly since the body control module ends up controlling all the lights (except for the driving lights) directly. In other words, since the BCM 'knows' which lights are on, it ultimately turns off the fogs when the high beams come on. You would have to get into the base code for the BCM to change it, or 'conventionally' hardwire the lights, bypassing the BC. In the case of TIJ, those cars were modded to varying degrees well outside of typical factory controls.
It would only take a SPDT switch and some wire to come up with a 'bypass' switch to, say, either work the fog lights conventionally, or have them come on with the parking lights.
You can use the existing relay that the fogs use. You'll be switching the control signal from the BC with a control signal derived from the running light or low beam power source. Doing it in this fashion you are simply switching around the coil of the relay, not the heavy draw of the lights themselves.
For those interested, it's the brown/green wire from pin 6 of connector A48 in the fuse box underneath, or pin 40 on A1 at the BC. The BC turns on the lights by grounding this wire, so you will have to come up with a means (small relay or transistor switch) that created a 'low' or grounding condition when the low beams or running lights are on.
Originally Posted by Sarcux
. . . figured out what wires to disconnect in order to let the fog lights remain on when you turn on your brights... hence you can have your driving lights and fog lights on at the same time.
If the reason for wanting your fogs and brights on at the same time are for better visibility during nighttime jaunts, you might consider rally lights. These mount higher than the factory fogs. You want to light up the road ahead of you, not the ground just in front of you!
As you said, this may be illegal and not recommended for seeing, but it would look cool.
Right now I am working on the FOGs working with DRLs then I plan to wire my driving lights to come with NO headlights or maybe just DRLs
Dave
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
12-23-2015 10:36 AM
