2007 Mini Cooper S: Help ID Part
![](https://cimg4.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/1120x2000/20180910_184636_62b0ac3538307fa893d5f9a3aaf2c25f159455d4.jpg)
![](https://cimg1.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/2000x1124/20180910_184924_447ecc5ace12965646e289b072cd05fe7258671b.jpg)
![](https://cimg9.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/2000x1124/20180910_183536_f5cc2c6ed2b20b61159e50e8a9eb8240d19af302.jpg)
![](https://cimg3.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/2000x1124/20180910_185151_0be6c75ef8ad41f918431da33d73d4aa892873fb.jpg)
Can anyone help me identify this part? 2007 mini cooper s. Some sort of sensor on air intake closest to turbo i am assuming. On opposite end of tube from MAF sensor. I have searched everywhere, but unable to locate the sensor plug nor the part the sensor plugs into. What is this called? Thanks for any assistance.
The part is a PCV heater. Your last pic looks like the cable that connects it to the ECU. All cable connectors are "keyed" so they should only fit one sensor / fitting, however they can be forced onto the wrong one. A few years ago, I was in a hurry and switched the PCV heater cable with the coolant temp sensor --- blew out the sensor. Use caution when reconnecting cables.
Use this site for an illustrated parts list --- https://www.realoem.com/bmw/enUS/select --- it'll help ID parts you don't know anything about.
+1 ^^ its part of the whole intake hose.
Rubber Boot N14 Engine Cooper S . 13717555784
Linked below here:
https://www.northamericanmotoring.co...id-needed.html
Is the plug on the wire harness side ok?
Linked below here:
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
Ok, here you go this is the intake hose boot wire harness plug for that N14 engine
https://www.ecstuning.com/b-genuine-...n/12527542852/ 12527542852 x 1
and
https://www.ecstuning.com/b-genuine-...t/12527543260/ 12527543260 x 2
and
RI!Y]3&aO&2W
05-23-2023 06:26 AM
ericfreeman
12
05-18-2017 05:56 PM
Mini-mize-Me
02-19-2013 07:50 AM
R50/53 Help identify these parts?
allforknot
12
03-18-2007 10:59 AM
