Fuel injectors
Fuel injectors
Are the Bosch injectors available through ECS the same as OEM? The kits to repair the original injectors vs. the new injectors is the same cost.
Also so I purchased a new fuel pump. Lower price. Made in Somewhere, Europe. Anyone
have a problem with these pumps?
Thanks mates, DR
Thanks mates, DR
Hello,
What year and model? I can check for you.
Same, MINI has just really raised the prices on those over the years.
https://www.ecstuning.com/Mini-2007-...A/Engine/Fuel/
Our HPFP from OES MINI is the same, just different box, the Genuine PSA is the same, but it comes in a PSA box. We are getting these from several locations as we saw some supply chain issues from Genuine MINI in the past and don't want people to be stuck with a dead car and cannot drive.
https://www.ecstuning.com/Mini-2007-.../Engine/Fuel/2
fuel injectors
Just to clarify. The genuine mini injector is exactly the same as the Bosch. Only for 75% less. And the fuel pump, even though its made in the Czech Republic is the same as that $1000 version available through Mini just a few months ago.
You have more than one pump listed. Even though the prices are quite different is the pump the same, from the same manufacturer?
Thanks, DR
Thanks, DR
Yes, We do it as MINI faces supply problems and large swings in prices on some products. And the prices on the aftermarket can swing also.
Fuel Injectors
So the pump and injectors are the same as genuine mini? I'll order the injectors this week. Do they com with the "o" rings installed and do they need to be shaped or can I simply install them? Also do you have in stock the ARP bolts for the pressure plate to flywheel? They should be around $15
Yep, yep, O rings installed like the pics. ARP bolts are on the site, if it states " In stock" its n stock here. Otherwise, it ships from them to you.
Here is all the ARP we offer for your N14 Engine MINI.
https://www.ecstuning.com/b-arp-part...16a-coupe-r56/
Myke@RPI
Want to Buy - All Other Items (archive)
07-10-2008 09:17 PM
Guest
12-23-2007 12:40 PM
mistro
03-14-2007 06:32 PM
Drivetrain Bigger fuel injectors = BETTER mpg ???
maxmini
07-07-2006 07:52 PM
