PCV repair question
Old 01-08-2020, 02:08 AM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
Originally Posted by SunBird
Training wheels for a real tune
Exactly
SunBird (01-08-2020)
  #127
Old 01-08-2020, 02:15 AM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
Originally Posted by njaremka
That hard pipe only goes between the vacuum pump and the brake booster. There is another pipe that goes to the vacuum tank, which then connects to the turbo waste gate. None of those tubes go to the intake manifold.
^^This is correct.
With the variable valve lift that these motors have, they basically run at next to no vacuum on the manifold. Hence the vacuum pump to provide enough to operate the brake booster and wastegate. Otherwise we’d have no boost and no brakes, lol.
Under normal driving circumstances, which can get a tad spirited, I usually only ever see up to 2 INHG of vacuum on my boost gauge. And it usually sits closer to zero.
The following 2 users liked this post by MrGrumpy:
iwashmycar (01-08-2020), Tuner Boost (10-11-2021)
  #128
Old 09-29-2021, 08:14 AM
omuroff's Avatar
omuroff
omuroff is offline
Hello all,
Can you please explain to me how we get a strong vacuum under the oil cap when the membrane is ripped?
Thanks, Ömur
  #129
Old 10-11-2021, 12:27 PM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
Originally Posted by omuroff
Hello all,
Thanks, Ömur
I am not the one to be able to explain the mechanics of what's going on inside the PCV system, but it is one of the symptoms.
I can't really help much past that.
  #130
Old 04-06-2022, 01:29 PM
mopho007's Avatar
mopho007
mopho007 is offline
I did not have the same luck as others. I went slowly and then heard a "pop" and the cap came off along with it two sections of the ring :( They where stuck to the diaphragm pretty good. Attempted to JB Plastic Weld the parts back on. As soon as I put the new cap on it cracked the ring in the exact some spots. So off to the dealer it goes for entire new valve cover :(
I did notice the 4 tabs are angled on one side, this leads me to believe you lift the the front end off the little post, and then rotate this cap rather than drying to pry it off? Why knows?
See angled end
See angled end
  #131
Old 04-06-2022, 03:26 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
The most absurd PCV system ever... I feel your pain bro.
  #132
Old 04-15-2022, 06:50 AM
Jwanck11's Avatar
Jwanck11
Jwanck11 is offline
Ugh! Sorry to hear that. I am about to tackle this and now I am scared again!
  #133
Old 04-18-2022, 11:25 AM
ECSTuning is online now
Received 2,092 Likes on 1,866 Posts
yep, with heat cycle its gets brittle. Sorry to see that.
MrGrumpy
R60/R61 Stock Problems/Issues
11-17-2019 07:38 AM
Kibbis
12
12-28-2018 04:03 AM
countrymanwot
12-08-2018 10:21 AM
Scooter24
06-19-2018 02:08 PM
texasmontego
10-09-2010 06:35 AM
Quick Reply: PCV repair question
