High Mileage Maintenance Must
My 08 Justa now has 172,000 miles and recently developed a bad oil leak. At first it appeared the oil pan gasket was the cause. Looking further, the leak was caused by the failure of the rubber gaskets of the oil filter mount.
The filter mount bolts to the engine block with the four bolts shown. Behind this there are oil passages and <importantly> a coolant passage. There are these two special rubber gaskets; these pieces become hard, brittle with age and heat. They will eventually crumble to the point of failure as mine did.
Significantly, while the replacement of the gaskets is simple *once you get to it*, the getting to it part is a huge amount of trouble. It is necessary to remove the exhaust manifold in order to do this and THAT is a large process.
The bottom line: IF you are doing other work that requires removing the exhaust manifold, maybe having cylinder head work done (OR if you are removing bodywork/ sheet metal and have access to the area) PLEASE pull the mount and replace these gaskets while you have the access.
NOTE: it is not necessary to drain the oil to do this, BUT(!) it IS necessary to drain the *COOLANT* as there is a coolant port in the block that is also sealed by this.
Below is a pic giving you an idea of what I had to pull off *just to get access*. If you are in there, don’t skip the chance to do this preventative repair.
This is good advice, it’s a pretty notorious spot for leaks, if you are in there, it’s worth the forty bucks for the gasket set. Mine was leaking and dripping onto the exhaust and burning off, so it never left any sign on the ground. Fixed it when I did my turbo. Since you are already in there. If you have an S consider replacing the auxiliary water pump while you are in there too.
I've done it from underneath the car on my S. Its still not fun, but the worst part is getting off the heat shield.
If anyone is doing this on a turbo car, now is the time to replace both turbo oil lines. The pressure line that supplies the turbo bearings with oil can eventually leak, and the lower line is a drain that can get crud built up in it.
Have fun,
Mike
Have fun,
Mike
rkymtn
11-28-2017 04:41 AM
marantz2010
07-07-2013 06:15 AM
Braminator
06-26-2013 08:10 PM
CBR600RR
14
04-17-2008 09:53 PM
