Rear rattling noise
Rear rattling noise
Hope someone has some insight on where to go from here. 13 MCS has a dull rattling noise coming from the rear suspension, going on now for several months.. Rattle is more prominent on chilly days while driving slow on rough road surfaces. Replaced rear shocks along with new upper bushings, replaced sway bar end links and sway bar bushings. Removed the rear shocks again to retorque the hardware. Even replaced the left rear end link again with another brand but the rattle still persist. Also checked the hatch supports and latch but noise seems to be coming from underneath. At this point, I'm open for any other ideas or suggestionsons. Thanks
i know this sounds silly, and i dont know how loud out metallic sounding this rattle of yours might be, but what about a nut or bolt in the jackstand hole in the hatch? or behind the hatch liner?
what about the emergency fuel shut off T-handle/cord on the drivers side of the hatch behind the little cubby hole, is the T handle flopping around just rattling against metal?
you would almost have to have someone lay the seats down and sit back there while you drive to tell you exactly, as best they can where the rattly is coming from.
even something under the rear seats rattling around as you drive?
Thanks once again for all your suggestions and Merry Christmas to all.
hotwhlz
R60/R61 Stock Problems/Issues
02-05-2016 02:11 PM
saturn5rocket
07-23-2010 04:58 AM
