Odd damage to head and pistons
had rattling sound posted on here but couldnt figure it out thought timing chain etc anyways got back from vacation pulled head and this is what I found, I did compression ck first it was 190 on 3 and then 0, all pitons and valve pocket have damage some more than others the shiny one is the worst. Just seems odd that if there was metal bouncing around that it would have hit anywhere else but edges ?? I originally thought rings had come apart.
car has 180 k on it and its a base model non S
Man, that's strange. If it's in all cylinders I can't imagine it's something physical like rings. I would think that would be more localized. How are the cylinder walls?
Probably not related to anything, but it looks like two of the plugs aren't all the way down, so either the wrong plug or not threaded all the way in. Not sure if you backed them out but it looks like there's carbon in the threads and I think the plug should be blocking those threads. Don't see how it could cause anything like what's going on though.
I guess you have a tough decision ahead of you, the value of a Justa with 180k vs. a set of new pistons, rings, bearings and maybe some head work. Sorry. I'll be curious if anyone can tell you what caused that.
Good that you figured it out because man that looked really strange. Are you saying all of the valve seats came apart in all of the cylinders, or just the one?
This is a very common problem with these engines. I dropped a valve seat 500 miles after I fixed my warped cylinder head. I pulled the head again and had all new (and deeper) seats installed.
Check out this link.
http://www.engineprofessional.com/TB/TB113017-1.pdf
jhiggs26
08-26-2013 04:56 PM
arnk0006
09-19-2012 05:50 AM
peter314
05-05-2008 05:16 PM
jbsf3
Tires, Wheels, & Brakes
19
10-24-2005 09:31 AM
