No oil pressure
No oil pressure
Quick back story: 07 MCS Car is a salvage rebuild, overheated due to no coolant from broken auxiliary cooling pump, head rebuilt, water pump replaced, timing chain replaced, thermostat housing replaced, valve cover replaced.
Ok so I got this thing back together and got a no oil pressure warning, yes I did put oil back in it, thought it could be oil pressure sending unit because the connector is broken but put a gauge on it to be safe. No pressure at gauge. Removed oil pan and oil pump, cleaned it out and verified it could pump oil. The pick-up screen was 1/4 clogged with melted stuff (maybe plastic) there were also some plastic bits in the oil pan. Reassembled, still no oil pressure. Checked oil filter housing for springs, all there. My next thought is something is plugging up the oil filter housing portion connected to the block.
So wise and all knowing internet friends, am I on the right path or am I missing some thing else? Any and all advice is appreciated.
When my N18 did the same thing after a rebuild, a friend advised me to take the valve cover out and then pour oil across the head and across the lifters and any oil orifice i can see, I had to hand rotate the engine so i can see the oil shooting...result: oil pressure light was off and oil was circulating fine.
Update for those that read this thread, the overheating that happened before I bought it was pretty severe. The valve cover had melted and started to drip plastic, it must have dropped into boiling oil and cycled through the engine, once it cooled it hardened and became solid plastic again. Unfortunately it decided to do that inside the oil passages in the head. I took the head back to the machine shop once I determined that oil couldn’t flow through the head, thinking maybe it was assembled wrong, they disassembled it and discovered a bunch of plastic pieces that were clogging all of the holes. They did apologize that they didn’t clean it properly, but I am just glad the found the problem. Now I just have to assemble the engine again.....
http://www.engineprofessional.com/TB/TB113017-1.pdf
ostojo
03-09-2022 01:43 PM
pnwR53S
09-27-2017 03:53 PM
garthg
10-25-2014 09:01 AM
BChili
10-11-2011 08:53 PM
Headlands
R55 :: Clubman Talk (2008+)
04-02-2010 02:23 PM
