Low speed fan or climate control panel?#?
Ok I know there is alot of threads on this I've been doing hours of reading this is what I've came up with.. I have a 06 mcs, its has the manual climate control, my blower motor turns on but my rear defrost, recirculation, and ac buttons do nothing dont light up wont turn on dont flash, I jumped the ac relay and the compressor kicked on, so I'm thinking it's the climate control, the fan did kick on after about 10 seconds but its seemed to be the high speed fan dont think the low speed fan has ever came on I've only owned the car for about a week now, just wondering if one probably could be related to the other or do I have 2 issues failed climate control and bad low speed fan resistor,
ECSTuning (08-05-2019)
You have the standard, cooling/heating system, (Non-Climate Control). Climate control systems have the digital thermostat where you set the temperature. Were you able to get the scanner to test the components? I would not try to throw money at this problem until you get the correct diagnostic tools, in this case a scanner that can test the components.
well i bought a foxwell nt624, ran my diagnostics, it wouldnt run the ac check not sure why keep say retry connection verify the key in on the on position... only other fault im seing is about passenger side air bag, i about to install a new super charger i guess i star by replacing the pressure sensor while im in there, there is no bmw or mini dealership within 100 miles of me dont know what else to do
Mini33073
08-18-2019 09:34 AM
