Oil Leak - Advice
Your valve cover gasket has failed. It's simple to replace.
https://www.fcpeuro.com/products/min...co-11127567877
Or you can find other vendors.
I replaced the gasket today. Everything was going great until I was putting the cover back on, and I managed to strip one of the bolts. So now I'm waiting for the new ones (bought 2, just in case another one bites the dust).
I took these four pictures with the cover off. Is there anything you all can see that I should be aware of or concerned about?
Currently at 122k miles.
I used Liqui Moly between 80-100. After that, Pennzoil Platinum High Mileage 5W-30 Full Synthetic.
Is there any way to clean this dirt off?? What would you recommend?
I have used SeaFoam Spray with great results; If I remember correctly, you can also use SeaFoam Liquid in your engine oil and it will emulsify all those carbon deposits. Follow the instructions on the label. I've never tried SeaFoam in my oil; since we are the original owners, and I've changed the oil every 7.5K miles.
What type of filter are you using?
This one:
That is a little dirty. My guess is the person before did the long services. Just keep changing the oil.
Lots of people like this stuff. And its liqui moly.
https://www.ecstuning.com/b-liqui_mo...00ml/lm2037kt/
On that end of the gasket you can take your time and clean off the cooked oil sludge and make sure it does not fall back into the engine.
DRoc7822
02-15-2016 12:47 PM
bigserb3
02-09-2015 02:24 PM
