Service light reset
Service light reset
https://www.northamericanmotoring.com/forums/stock-problems-issues/135901-r56-service-brake-lights-etc-reset-procedure.html
Good day folks. I have followed the instructions on the sticky above and was successful in getting to the point where i can reset the rear brake service warning. But everytime i do it, the reset doesnt reset the negative number. I was able to reset the front brake warning, the oil change, etc....but the rear brake warning will NOT reset. Anything else i can try? Thanks!
You'll have to do one of two things.
1. Buy a new rear sensor and perform the reset procedure.
2. Cut the end of your existing sensor, strip the wire ends, attach them together and perform the reset procedure.
I personally did #2 because IMO, the sensor is a waste of money. I shrink wrapped the wire ends and zip tied it up under the car so it wouldn't get into trouble.
Mike Miller
10-23-2018 05:54 PM
savk
09-05-2011 08:08 AM
Interior/Exterior Changing Fog light bulbs, Oil Reset/Service?
ravenhawk
10-12-2006 09:29 AM
