6/12v tester
6/12v tester
Anyone know of an inexpensive 6/12v power tester that can be used to power and trigger hardware such as actuators/solenoids, lights, etc.
something that outputs power to said device so that it can be tested.
i dont know what they call them other than a tester, but its not a normal multimeter, it outputs voltage to test if something is working.
Thank you sir! That is what i was afraid of.
i need one anyways have for a long time but i wont be jacking around on the mini with it outside of bulbs
i cleaned one of two VVT solenoids but wanted to test the actuation of them with a tester
Guess i will spend the $36/ea on the aftermarket brand solenoid and see if it helps my crazy idle issue
i cleaned the intake side but it didn't help.
the exhaust side is friggin Tori bit bolts and they ar soft probably the softest bolt i have sent for ages, and one size too small warped the toro teeth and the size that fits in the intake side doesnt fit the exhaust side so i am going to try and see if a flat head screwdriver will fit enough i can unthread it and clean the solenoid.
Heermann
11-16-2002 08:06 PM
