New radiator issues
New radiator issues
Gentlemen, I have put 2 new factory radiators on my 2005 jcw r53 in the last year. One month ago I put the second one on and it is leaking exactly where the other one was, looking at the front of the car, 3 inches down about 5 inches long, anti freeze is setting on the coils, very minor leak, car is not heating, but anti freeze level is dropping slowly. Sitting in garage I may see a quarter size drip on floor. Anyone seen this issue, radiator is under warranty if I want to pay mini to install, which is twice what a new radiator cost. THOUGHTS I am thinking about going to Mishimoto.
I'm glad I stumbled upon this thread. I'm about to do cooling system surgery on my daughter's '05 R53 and was wondering if I should splurge on the Mishimoto. Sounds like there's not much point, so I'll stick with an OEM-like alternative from O'Reilly - it has a lifetime warranty, although the process of replacing it is pretty painful, so I just hope the new one doesn't leak. Her cooling fan is making a heinous noise and there is coolant leaking from a few spots, so I'm going all out while I'm in there, and am replacing the reservoir, thermostat and housing, radiator, cooling fan, and all the hoses. The silicon replacement hoses are the most expensive part of the whole thing....
Ian
Ian
Thanks. I assume a new fan assembly will include the controller and resistor, or is that bad assumption?
Anything else I should do from a preventative perspective while I have the front end off?
Ian
If you have bumper cover fog lights, it will be easy with the bumper cover off. If they are damaged, Amazon have after market and oem replacements.
You also want to look at the Vibration dampener on the front of the crank, as age makes them go bad also. ECS Tuning has a good one, if you need one. (others to, including Amazon)
You should also check the belt tensioner bearings, they should not wobble at all.
ECSTuning (08-23-2019)
Original poster and someone else said they're on their third radiator..
. My r53 making 230hp currently is running lots of OEM parts bought through FCPEuro, 4 throttle bodies, 2 Mishimotos, 2 Waterpumps, etc. all replacements following the initial were free.. just a thought for those sick of paying for the same crap over and over. Caveat: I do all the work myself so I don't have to pay for labor.
![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
Cenla Mini (09-14-2019)
JAB 67
03-30-2016 06:27 PM
