Mini cooper r53 belt tensioner problem
I was hoping I could get some help with my belt tensioner problem. I removed the 16mm bolt that holds the tensioner at the top to replace the belt but now that it all put back together; my belt is extremely loose and its the exact same one as the previous one. I thought I might be able to replace the belt without the tool using this method but it did not work.
Are you sure it's routed correctly? https://cdn4.pelicanparts.com/techar...mall/Pic15.JPG
the other thought I had was maybe you're trying to put the tensioner back in the wrong spot? I can't remember if there's multiple holes there or not.
https://www.pelicanparts.com/techart...eplacement.htm
Belt tensioner problem
Ok so thank you guys for the feed back, I know it seems dumb to have tried doing it the way I described it but I was just testing it out and it failed. I did order the belt tensioner tool and will have it in a few days and also a new tensioner assembly just so that I know it's new.
Bernie (NoVA)
11-20-2017 10:32 AM
arth4
08-09-2016 10:02 AM
VII
05-26-2014 03:27 PM
daonlyillwiz
02-04-2014 06:28 PM
