Outer ball joint removal - question
Beating on the control arm with a sledge hammer hasn't worked. Looking closely at the portion of the steering knuckle into which the outer ball joint fits looks to me as if the recess is open to the top. So, if I remove the axle can I beat on the ball joint from above?
You can beat the joint from above but you need to set up a solid support on the arm to do that.
That should work to get it out of the knuckle. I used, a chisel, flat bladed screwdriver, hammer, and some cursing. You might avoid pulling the axle if you use a long punch or screwdriver. I put some antiseize between the ball joint and the steering knuckle so hopefully it'll come apart easier next time.
RudeJoe
16
01-30-2017 06:41 AM
YEZGUY
05-07-2011 04:27 PM
JAB 67
01-23-2009 10:49 AM
