Not firing at cylinder #3
Hello
I am new in the group, appreciate your support.
I have a 2009 mini cooper base N12. I have rebuilt the engine by replacing the gaskets, cylinder rings, block and head resurfacing, water pump, thermostat, etc..
Engine started perfect, running smooth as expected but after 15 minutes running at idle got misfiring at cyl. 3. Ignition coil got melted inside. We replaced the coil and spark plug but no more spark in this cylinder.
We think ECU got damaged because not sending ground pulse to activate the ignition coil 3.
Pending to your comments and advise before purchasing a new ECU.
Thanks!
Thanks!
themarques
03-01-2012 01:13 AM
