CEL 00289D and 002C96
[SOLVED] CEL 00289D and 002C96
Hi!
I have an mcs r56 2009. When I ran carly diagnostic I lately read the two codes
00289D DME: Boost-pressure sensor, electric
002C96 DME: Power management, closed-circuit current violation
The first is the map sensor which I will remove and clean. The sensor has the 0261230135 number on it.
does anyone know what's the difference with the 0261230134?
I dont know what the second code might be. Any thoughts?
I think I sorted it out. The map sensor (boost sensor) was a little dirty. I removed it and cleaned it. What caught my attention is that it was a little oily. I checked the pipes but I didnt find any oil. I removed the tmap sensor located on the left pipe before the noise maker and it was dry and clean.
The other fault I think was because I leave the obd reader plugged. I removed it and I will report back after a week.
The sensors are map (135) and tmap(134).
