A few codes
A few codes
My wife has been driving the car for a while know and she is about as observant as a corpse. I got in the car this last weekend and it had the TPMS and DSC light one. I assume a speed sensor, as that seems to be the main culprit. Plugged in the scanner and got all these messages. See below. Not sure about the GM codes? Cleared them all and some variety of them can back a day later. Non of them showed the speed sensor, so not sure it is it. I them read some where it could be the Steering angle sensor, so I used the scanner to calibrate it and all went okay. Next day, codes are back. This time I pulled the sensor and did the cleaning and minor adjustment of the contact pins. Reinstalled it and could not get it to calibrate. Any thoughts on where next to go?
1613/not present: DME: Serial communication connection, ASC
5E5C- ABS-DSC; Initialize run flat indicator
5E16- CAN Instrumentation
5E1E- Steering Angle Sensor CAN
5E18- CAN: Data Error from Engine ECU
5E11- CAN: Control Module
INSTRUMENT PANEL (KOMBI)
60- CAN Bus, Bus Offline
61- CAN: no communication
67- CAN: no message from KOM2
62- CAN: no ABS message 1
LWS: Can-bus communication fault
Last edited by lotter1; 10-22-2019 at 03:29 PM. Reason: Removed annoying pics and listed codes
Just a WAG but it might be a good idea to check the speed sensors to look for a sensor wring harness damage or really anything out of the ordinary with the sensors.
One could consider even replacing them just to throw parts at the codes. While this is often dismissed as amateur auto wrenching sometimes it is all we amateurs have available. Of course to do this or not depends upon the cost of the sensors and how much work is involved and how you would feel if afterwards the symptoms were still present.
If you choose to not throw parts at the symptoms you have to get a high confidence diagnosis as to what is going on. That requires you get lucky and someone here can be more specific with his help or you search online for any further info on the error codes and what they mean.
My limited experience -- with another car -- was the tach was part of the instrument cluster. The only info I know for sure that was stored in the cluster electronics was the odometer reading. There might have been some settings regarding mph vs. kph, 12/24 hour clock, etc but the odometer was the biggie. I had the original cluster replaced with a used cluster. Afterwards everything was fine -- the problem was the airbag light always on -- this was confirmed to be a cluster problem -- and the cluster LCD developed spiders -- but the tech was unable to edit the odometer mileage (approx 93K) to my car's mileage (around 300K). The computer tools (factory supplied) he had were limited to only changing the odometer mileage if the mileage indicated a new cluster.
There are speedometer repair shops around that can move data from one cluster to another. I knew of one but decided to not bother.
I did note in the car's owners manual the details of the cluster change including the original cluster's miles and the "new" cluster's miles. Also I had the service invoice which detailed this as well and when I sold the ar some 15K miles later I divulged all this to the buyer (the dealer where I had the car serviced).
Boudicca
04-26-2016 07:05 AM
