Base Cooper oil leak(s)?
My SO's car has a fair amount of oil related issues:
I figure I would need a new oil pump solenoid (VANOS?) $150
Oil filter housing gaskets $30
Front main seal tool + seal $200
Does that sound right?
- oil pump solenoid harness (dealer wants to repair rather than replace) $625
- oil filter housing gasket $1210
- crankcase front main seal $1000
Changing the front seal involves re-setting timing too --- timing tool set in addition to the seal tool, and possibly a new set of cam / crank bolts, which are TTY single use bolts. Take a look at these instructions (same set used by dealer techs) for a better idea of what's involved --- https://www.newtis.info/tisv2/a/en/ --- just need the last seven characters of your VIN.
Here as well: https://www.northamericanmotoring.co...irst-post.html
No mention of timing.
Well had the dealer replace the oil solenoid harness and will do the rest. Also the dealer said the harmonic balancer/crank pulley needed to be replaced to the tune of $500 (part) because oil had leaked on it and damaged the rubber on it. Not sure how oil damages rubber but I digress. But it does explain why the front main seal was quoted so high. Also oil filter housing gasket include all new bolts/gaskets/etc...which jacked the price up as well.
Will report back with any issues I may or may not run into.
I used a Fel-pro from Amazon for like $12. It fit perfectly and has not leaked a drop since. If i had it to do over I would probably go to with a better manufacturer. After doing the job, can you believe the dealer quoted you $500. I find their prices are now truly ridiculous.
FWIW the total quote from the dealer was $4400 for the 3 things I listed plus pads and rotors. They were trying to replace every part they touched, manifold bolts, heat shields (really?) and every single bolt. It was crazy because their quote just listed the service and no mention of any parts involved in it. In the end I did pads and rotors on all 4 corners myself for $150, I did the main seal and belt and the dealer did the oil solenoid harness + oil change for $550 so I am right around $700 for all of it.
mkov608
02-01-2024 05:29 AM
dmyer
01-16-2018 07:52 AM
