Snapped engine bracket ground attachment
Last night I replaced by belt tensioner and had to remove the upper engine mount bracket (cast aluminum piece). Upon reinstalling the ground strap, the mount on the bracket snapped. I temporarily attached the ground to one of the supercharger mounting bolts. Is there a good repair, short of buying a new bracket? Or, is there a better alternate location to mount the ground strap to the engine?
https://www.northamericanmotoring.co...dding-wth.html
You would have to make sure its connected and flat/clean. You Might be able to drill out a small hole on that mount and then use a solid bolt with a nut on the other end so it will not walk out.
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
BTW - I bought the car a week and half ago and I'm already have three orders from you trying to get the car sorted! I'm now working on my fourth order as I uncover more things (and I'm still in the engine bay)...
Welcome ![Smilie](https://www.northamericanmotoring.com/forums/images/smilies/smile.gif)
Thanks for the orders and support and if you need anything I am always here.
