Vanos rebuild?
Vanos rebuild?
Is there a procedure to rebuild/disassemble the vanos from an R56 N14 S? I did some searches here but nothing specific to rebuilding or disaasembling the vanos. I am in the middle of a valve stem seal changeout and figured I would to the timing chain stuff while I had it all apart.
If you suspect the Vanos system to be "bad" best replace it with a new one. 'course, you can check with a BMW/MINI parts department to see if the parts catalog lists any serviceable parts available for the Vanos. If it does then the unit could be rebuildable provided one knows how to get it apart without wrecking it and get it back together again.The unit probably has some very close sliding fits that do not lend themselves to repair/renewal.
AZdsrt (12-17-2019)
mildensteve
02-10-2020 11:12 AM
Nui
08-24-2017 05:01 PM
ahmedalsurmi
03-28-2016 09:21 AM
