Towed this morning
Towed this morning
Hello again forum, 2005 MCS r53, lately I've had a EML light that comes and goes. No check engine light.
This morning I felt some engine hesitation. Dropped the kiddo off at school. Turned the engine off for a min and it would not start. The starter turns, rough idle, dies, and the speedometer vibrates and makes a vibrating noise.
Once back home, inpa not registering any engine codes, no ews codes, the instrument cluster / gauges do run a test but inpa does throw a few script errors. But I'm not sure if that is something new.
The battery reads 11.65v. Could a bad battery cause this behavior?
Anyone have any guesses, experience something similar?
yes sir, your right. the battery seems to have been causing the rattling / vibrating / buzzing speedometer. I put in a new battery and no more vibrating speedometer.
It cranks well now with the new battery but no start. tried a few times. Then I noticed that I was not hearing the fuel pump prime when I turned the ignition. Gave the back seat a few smacks. I then could hear the pump moaning, almost sounds like a frog. It started right up. Then died. Its the pump. No fuel. That would also explain the hesitations I was feeling right before all this.
I think its a dead / dying fuel pump. But please stop me if I'm going down the wrong path, forum. Or if you can think of anything that I can try before replacing the pump.
Will do, sir. Can't hurt. My thinking is that if it were a ground issue the starter would not turn. Wrong assumption? The starter is quick with the new battery.
The car is a daily driver. It does about 60 - 70 miles a week. Work is about 3 miles one way.
ssoliman (02-02-2020)
Update: installed the new fuel pump today. Running again. so this one has a happy ending.
also brought the old battery to auto zone and had them test it. Bad.
so in short the buzzing speedometer was caused by a weak battery and the hesitation, no start, was the pump.
the pump was easy enough to swap. helped to watch a few videos on YouTube first. And the fun continues
The following 2 users liked this post by ssoliman:
Andy_S (02-04-2020),
user 7389739 (02-05-2020)
drrigg
02-12-2018 09:38 AM
tlmease
01-20-2016 02:58 PM
