Pre Cursor to the Death Rattle '10 R55s
Not sure if this has been covered before, but at times, coming to a stop as the RPMs slow, it sounds like the timing chain is rattling until the mini settles at idle. Is that normal or do I need to be concerned? I bought the car with 30k miles, it runs great otherwise,
I 2nd the timing chain tensioner. It shouldn’t “rattle”, so buy a new tensioner and change it. That is the one piece of the puzzle that has a floating type adjustment on the chain. All other connections are solid and bolted in position. When you remove the tensioner, try to compress it with your hands. It should be very difficult due to the amount of spring resistance.
frappucino
02-09-2015 11:37 AM
stxmini
08-18-2012 07:21 PM
