Coolant system cleaning - What is most EFFECTIVE power flush process?
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
This question IS about what process is best as dislodging any accumulated stuff in the system Which hoses to forward to back flush from/to, which chemical (if any) to use, tips and tricks. etc.
What this question is NOT about - This questions is NOT about how to get all coolant out or worrying about having tap water in the system. It seems that this ShopVac process is good at getting out any old liquid https://www.northamericanmotoring.co...ush-diy-2.html
I'm reconditioning a 2002 R53 which has a brown rust looking stuff in the coolant and the heater core disconnected. I'm looking to best dislodge and flush out any rust particles and foreign matter before refilling system I will also replace the existing heater core and reconnect it. The existing heater core does not seem to leak tough it does have rust color inside the and seems to have restricted flow so I'll replace it as a preventative measure.
Since the heater core is disconnected already, maybe flush through both heater hose will get the whole system?
I'm not 100% sure I understand what how you're trying to flush the system. I had some brown funky stuff in my coolant system recently. I put some prestone coolant flush stuff in it, drove it for a few days (according to the instructions) and then did my usual drain and fill process. I usually run it up to temp, then drain, refill with distilled water and repeat until what drains out looks pretty close to what goes in. I don't have a shop vac, but that method does seem promising and perhaps faster.
I was amazed at how clean the system was after the prestone flush, and the coolant has remained very clear and clean in the past 18 months since doing the chemical flush.
