07 Mini Cooper won’t start
I have 07 Mini Cooper s turbocharged and It cranks but doesn’t start I check for spark I have spark I tried starting fluid still won’t start I have two codes p0190 p0697 and I I check the connections and there fine and then went to the fuel pump in yank and when I turn it on I hear no whining sound nothing but if I try to crank it then turn it off wait a min a hear a motor winning in the back where the fuel tank isi check the voltage going to the pump and it only reads 2 volts when I turn the car on and try to crank it I also checked fuses and relay and they work. Please help I’m running out of options and I don’t wanna drag it to the dealer of yo
A quick thing to is if after you try and start pull a plug, if it doesn't fire see if there is the smell of gas on the plug.... This will tell you if your getting fuel, you have already confirmed spark... you need Spark, Fuel, Air and Timing... Timing I doubt is your issue, sounds like fuel at this time... so start with the sniff test! or if you have inspection camera pull a plug and try and start the car and see if fuel is sprayed into the chamber. If nothing its time to go to the sensor.
P0190 = https://www.obd-codes.com/p0190
Curtesy of minimania
P0190 - Fuel Rail Pressure Sensor 'A' Circuit
P0697 = https://www.obd-codes.com/p0697
Couldn't find this code on Minimania.
Based on these two codes i would start with fuel rail pressure sensor "A" circuit
https://www.pelicanparts.com/techart...eplacement.htm guide found here.
I'm not a mini expert by any means but have tinkered with mine a bit. Some of the folks here will have more suggestions. But your codes lead towards the pressure sensor, reading the P0967 code description seems as though it is a subsequent code to the primary one. (obviously your dealer will have a special diagnostics tool and can find out alot more detail surrounding exactly what is wrong.)
Confirm your part number match but this is something that it should look like.
I bought the Mini Cooper running and blew a resistor on the fan and it over heated it and the thermostat melted and plastic got all in the block and head so I took the whole ending out put a new thermostat and sensor and got the head hot bathed and resurfaced and I put new valve seats in it and lapped all the valve(valves were cleaned too) and I put it all together and I did a compression test before I put the engine in and it rear fine I don’t remember the number but I looked up the specs for that when I did it but I don’t smell any gas on the spark plugs and I also took the feed line off and tried starting it and no gas came out and I did unplug the ecu when I took the engine out I don’t know if the tripped the fuel cut off switch. But Ik for a fact I didn’t have a fuel problem when parked the car to work on it
Odd, I did a Timing job, then ended up having to replace my DME, and now I'm faced with the same codes you have.
https://www.northamericanmotoring.co...placement.html
Fun.
Fun.
I ended up sending the new(used) dme, my cas and key to a guy in the stated who took care of it all for me! Then it was plug and play!
Gennie (07-04-2021)
tntaussie
03-15-2022 03:23 PM
NCapurata
04-01-2019 07:54 PM
BETOGTI
01-28-2012 06:17 AM
