Need help with R56 codes
Hello,
I pulled the codes off my 2013 R56 Justa. I added a note with the info I was able to find. One note, I replaced the factory head unit and i believe that is causing the Can Bus errors.
C994 Switching Centre Steering Column
2FD9 EWS-DME electronic immobilization
DA04 K Can Low
E104 Can Wire Error
A559 KL30g f cutoff
A8BD registration plate lift defective
D104 TPMS
D115 TPMS
Any help would be appreciated!
DA04 K Can Low
E104 Can Wire Error
A559 KL30g f cutoff
D104 TPMS
D115 TPMS
Something has caused these codes, does the car start?
One of your codes is tieing to your CAS (EWS) module which needs to share a 128byte code with the DME (ECU).
another one is your steering lock, which also talks to your CAS from what I have read in other sources.
Some of your other codes I couldn't find.
Hate to say it but a standard OBDI-2 reader doesn't get all the german codes that our Minis throw out now days and sometimes needs more advanced diagnostics. @MiniToBe is a great resource and might have a few more suggestions.
I would start with the codes that we can find information about.
I did not do anything to the car before reading the codes. I have an OBDII scanner and I just check them from time to time. I have seen the CAN BUS codes before but not the other ones.
No I clear the codes out after I read them each time.
Well Jay is right, you don't want to use a standard OBDI-2 engine code reader. You need to use a BMW Mini specific one. You may have a problem that is not being picked up that makes all these other have some kind of mental connection. In addition, the codes get translated into something dumb. So the Mini Code may read out something specific to your car while the standard code reads out to be something more generic on an American car that doesn't make a lot of sense in your car. In fact, I have seen really stupid Mini codes like the antenna on the radio is unscrewed the last time you did a car wash make it sound like you have an electronic short in your car or something.
Don't even bother trying to connect them up...it is an exercise of futility IMHO unless it is like for the O2 sensors or basic emissions. Those have to map up so the people that check your emissions can fail your car. lol
Thanks for all the responses guys!
If you are using an android smartphone, I can recommend:
Deep OBD for BMW and VAG:
https://play.google.com/store/apps/details?id=de.holeschak.bmw_deep_obd&hl=en
bimmer-tool (BTool) Lite:
https://play.google.com/store/apps/d....pw.btool.lite
Both report errors from all ECU's, are free, free of trackers and do not require proprietary adapters. They work with Bluetooth or WLAN adapters as well as D-CAN/K-Line USB adapter cables (such as those cheap chinese ones that work with INPA). Note: an OTG capable smartphone is required in order to use a USB cable adapter.
Deep OBD is a bit tedious to understand and configure, but has more features. It provides more detailed error explanations, including plain text descriptors. It can also be used to monitor (both graphically and/or numerically) every single reported sensor value in real time, for example onboard voltage, coolant temperature, etc. It is also compatible with Volkswagen group brands, but I've never tried that myself.
BimmerTool lite is (much) easier to setup but will only show the error code (lacking the plain text description).
I have installed both on my smartphone and find myself using Deep OBD pretty much every time.
I got a blue driver ODB device, my 2012 countryman S, shows only one code/error:
1 instrument cluster code: a559 status HISTORY - KL30g f cutoff
frequently reported fix-replaced battery.
I've posted on another forum-the only issue with this car has been an alert about the battery discharging quickly-I assume this code is related to this?
tanjg
09-23-2018 06:06 PM
