vacuum pump rebuild kit or replace pump?
came across this on ebay: https://www.ebay.com/itm/RKX-Vacuum-...ZzWOt&LH_BIN=1
my pump is leaking oil. original pump, 95k miles. 07 r56 S. do I replace the pump or do the rebuild kit?
I would rebuild it. Done two of them so far. Works great. Make sure you clean the check valve in the lower brass fitting circuit by blowing cleaner (I used brake cleaner) through it. Otherwise it may stick open and you will suck oil into the reservoir after shutdown. Been there done that. A pain to remove the reservoir, drain the oil, replace the hoses.
