r56 2007 MCS another idle problem
Hello there, I've been looking for solution for few months and finally decided to ask here maybe someone had same problem and can help.
I've got r56 2007 MCS and I've got idle speed fluctuations (it's not as bad as rough idle videos on YT, it doesn't stall, I'd say 50-100), sadly there are no stored faults, here's what I've done so far:
- turbo rebuilt
- new intake pipe (helped a bit)
- new timing chain set
- valves cleaned
- vanos solenoid cleaned
- non return valve cleaned
- TB cleaned
- new plugs, battery, alternator, HPFP and maybe something else I've forgot to mention
When I turn AC on as RPM go a bit higher it makes fluctuations less noticeable.
I've been to few independent shops but with no success.
Any ideas? I'm clueless.
- turbo rebuilt
- valves cleaned
- TB cleaned
small update, today i finally got 2 codes related to superknock (i've got cheap reader but its a clue) so faulty injectors are possibility, i hope it will be fixed finally
i will get back with update later
i've replaced whole valve cover with pcv tube last year so it's not likely the cause but thanks for idea
Davbret
55
03-10-2019 03:04 AM
Ixx
07-11-2017 07:09 AM
btallack
04-14-2008 05:46 PM
