Repair of nipple on Fuel Tank Breather Line part # 13907515434
R53 Repair of nipple on Fuel Tank Breather Line 139075154
Doing a low budget rebuild and used a small threaded nipple from a motorcycle application. Filed down the broken nipple, and tapped. The O-ring compressed too much and squished out so used a little Teflon tape around the threads just in case. Something similar may be done with a piece of hard plastic tube and JB Weld…or something else….maybe use the short section of hard pipe for the repair and then use flex hose from this T to the larger diameter pipe.
It is #4 here https://www.realoem.com/bmw/enUS/sho...diagId=13_0977
Below are the threads I used to ID the line and conceive the fix
https://www.northamericanmotoring.co...rger-horn.html
https://www.northamericanmotoring.co...i-get-one.html
https://www.northamericanmotoring.co...this-part.html
https://www.northamericanmotoring.co...ification.html
Google carb sync nipple. Something like 5mm thread IIRC is what I had. 6mm may also work...or as the post says, a piece off tube and JB weld.
https://motomummy.com/products/motio...BoC2kYQAvD_BwE
L3Mix
01-18-2016 11:23 AM
