Timing case cover - what else to do while in there
Looks like I'm leaking from the lower rear corner of the timing case cover. Already did the oil pan gasket.
by #8
Other that the crankshaft seal that were disturbed by taking it off and the oil pump o-rings (and the cover gasket obviously), what else to do and look at while I'm in there?
Budget car (not motor) rebuild on 2002 R53 178k, high compression numbers.
I'm not inclined to to the harmonic balancer (budget rebuild). And I'm not going to race it, would almost prefer a non S but I'm learning a lot! :-)
I found these resources
https://www.newtis.info/tisv2/a/en/r...covers/AvlxUaK
https://www.northamericanmotoring.co...ml#post4536584
https://www.northamericanmotoring.co...r-removal.html
by #8
Vendor
Well with 178k I would for sure do the timing chain kit. We see them stretched at just 130k and you have to pull the timing cover to do it.
https://www.waymotorworks.com/timing...0-r52-r53.html
Also make sure you replace ALL 3 seals on the cover
I know you said your out of budget, but I would HIGHLY recommend doing the crank pulley at the same time. They are all going to fail at some point as the rubber in them just drys out and they fall off.
WayMotorWorks (05-22-2020)
Yes it just might....Hope it last though...(teasing - technically, I asked while I'm "IN" there, and HB is outside of the cover [wink]) and I really appreciate all y'alls comments.
user 7389739 (05-23-2020)
This looks quite stretched...what say ye internal experts?... How much effectiveness of left in the tensioner piston?
Here's the pic comparison WMW
Vendor
Yes replace it looks just like the pictures we have.
The key is the entire kit as not only is the chain stretched, but the sprockets the teeth get deeper like bicycle sprockets and you need to replace them at the same time.
I'm getting ready to do the same job...replace the timing cover gasket. I have 190k on my motor, so I'm guessing it would be stupid not to replace the timing chain. How much more involved is that? Is it as simple as pulling the main gear off the bottom, taking the valve cover off and pulling the chain off of the cam gears, and then keeping everything in time when you install the new parts?
I'll bump this thread as I am in the same boat. Leaking oil from the timing cover, car with 217k + miles, and no record of the timing chain or tensioners being changed prior to my ownership. So I'm facing a while-I'm-in-there moment. I've seen the cam locking tool. Is this a must? How hard is it to get the sprockets off? Thanks
In my opinion, the W11 timing setup is very, very simple.
Island_Moose
09-30-2020 04:05 AM
Marktheman
09-06-2015 06:15 PM
