STILL stiff steering, after new pump, lines, reservoir
More detail in my full build thread:
https://www.northamericanmotoring.co...ml#post4536856
Here’s the deal - Bought her with what I thought was a failing (but not all the way dead) power steering pump.
The was very stiff when stationary, but fine while cruising. The pump was especially whiny compared to my last R53, and the resistance was constant through the range of motion of the wheels. Meaning there were no points in the rotation that were more difficult than others (which would make me think it was a steering rack issue, instead of pump).
No problem I thought. So I replaced the pump with a new (remanufactured) Bosch unit. Cleaned and replaced all the clamps on both power steering hoses, and replaced the reservoir which was leaking.
Reassembled all with with new CHF 11s fluid, and yet the steering is still a little stiff.
it’s MUCH better than before. there’s no pump whine and no leaks, but it’s still fairly stiff when at very low speed (under 10mph) and the wheel won’t turn back to center if you let go while driving at those slow speeds.
The steering column looks fine and not inhibited in any way.
The universal joint connecting the shaft to rack doesn’t look like it’s binding at all, and I lubed it a bit just in case.
My next thought is an issue with the rack, but I wanted to ask advice before dropping the subframe again.
Running out of ideas!
thanks
Trag
thanks
Trag
Did you bleed the system?
Thanks for the thought
If it isn't jumping out at you, maybe throw $200 at a good B&A shop to find out what's up(?). Then do the work yourself of course.
Only thing i can think of is the steering column U joint itself. https://www.northamericanmotoring.com/forums/stock-problems-issues/315299-diy-lower-steering-column-replacement-any-tips.html
https://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Steering/Column/
orvillespooner
03-13-2014 09:02 AM
