Electrical issue
Electrical issue
Hope this is the right thread...
My mini an R56 / Cooper S with 180k miles.
Situation: I was driving and the AC blower stopped working. Also, I noticed the sport mode was off too. Then I started to check everything in the car and wipers front/back also are not working.
Any information will be appreciated.
Quote from newtis:
Switch-off of individual consumers or power consumption reduction > only for vehicles with high equipment and IBS
On vehicles with IBS, consumers may be reduced or even switched off altogether, even if the engine is running. While driving, only consumers that are not safety-related and not readily perceptible are reduced or switched off altogether, e.g.: pulsing of the heated rear window or pulsing of the seat heating, reduction of the blower electric motor by a fraction etc. In the case of vehicles with diesel engines, the power consumption of the electric auxiliary heater is adjusted.
The shutdown of individual consumer units or reduction of the power consumption lowers the power consumption in critical situations. This prevents the battery from discharging.
Consumer shutdown is only activated under two preconditions:
- Battery charge state in the critical range
- Alternator subjected to full load
https://www.newtis.info/tisv2/a/en/r...supply/XpiDfcv
malibujoey
10-14-2016 06:28 PM
goblue96
06-28-2012 09:39 AM
R50/53 Weird electrical issue . . .
MisterDangerPants
10-25-2005 02:12 PM
