DSC and low Tire Pressure Lights on
I have a 2004 Mini Cooper S with ~125k. A few days ago, the DCS light and low tire pressure light came on. I thing I have read all of the threads on the topic but there doesn't seem to be any consensus answer. Only have the 2 lights on.
- Speed sensor
- steering column sensor
- Alignment issue
Is there a link that describes the correct diagnostic/troubleshooting process? The speed sensor is relatively low cost but I have heard that the steering sensor is pretty expensive.
- Speed sensor
- Alignment issue
Something similar happened to me once. As I recall, I had run over some loose gravel, uphill at driveway speed, and one or both tires spun and the lights came on. After verifying tire pressure at all four corners (I have run flat tires) I reset the RDW system (pushed the "(!)" button by the E-brake handle ~5seconds, key ON engine OFF) and they both went away.
What scanner are you using to read the codes? the $20 bluetooth obd dongle's won't read the wheel speed sensor faults. I would lean towards a wheel speed sensor, wheel bearing, or both. If you need a scanner to check the wheel speed sensors, I recently got this one it read and reset my airbag light. I think it has pretty much all the functionality as the schwaben/foxwell scanner, but not the price tag.
Low battery/bad alternator
On a 10 year old 2006 R53 had similar symptoms as the alternator failed and the battery started to have low voltage. As the battery drained, more lights, loss power steering and then finally no engine power. We were on the Dragon at MOTD. We swapped batteries to get the R53 back to our cabin. And then found an alternator and swapped that out to get home.
I took a closer look at the front passenger wheel. I think I can visually see that the wheel alignment is off. Won't get to look at it more close look at it until later today. If I can visually see it, I must have bent or shifted something.
(I should have started this dicussion in the Hatch talk sub forum. Apologize for that)
jeffrimerman
07-12-2008 03:01 PM
