Maze of Coolant lines Help!
Since I purchased this R53 in pieces (and the cheapest in the Wold$300) lol...I have no idea how the coolant lines are routed.
The previous owner had a bypass plate installed to replace the oil cooler but later looped it because the remote mounted oil cooler was damaged.
I have the OEM cooler installed, but literally have no idea how and what the routing of the lines should look like.... RealOEM.com is somewhat of a help. But does anyone have
detailed pics or suggestions for the 03 MCS 6speed????
On the left side of motor going towards the fire wall. The yellow clips are connected against the firewall.
these are two separate “mazes”...looks like they are connected in the pic but not. One is laying behind the other
From the top down, two hoses into the reservoir, one hose into a metal pipe (left side of the engine) and one hose into the thermostat housing. The skinny hose from the radiator goes on the skinny nipple below it (in the pic it’s not connected yet)
at the bottom two hoses on to two metal pipes that run along the back of the engine to the oil cooler
user 7389739 (06-29-2020)
JCW_CBLACK
09-05-2019 10:29 AM
