Another Trifecta Post...with a twist.
I have been reading everything i can about the trifecta, but nothing i have found is my "exact" problem.
When i scan my car, it tells me that the drivers side (left) wheel sensor is not working. I even check the data stream to confirm that the other 3 wheels show a speed (the same one even), and the left front one stays at 0.00. I thought, great change the wheel sensor and we will be good. i swapped it out, and the problem stayed... I then swapped it out with a known good sensor (the one from the passenger) and it still did not work. I replaced that sensor back into is home (right front) and the sensor still worked. I wanted to make sure i did not damage it while removing it. I tried to do my best at a round robin diagnostics. I even made it so i could connect the working sensor (front passenger side) to the wire harness plug for the drivers side, to try to check if the module was processing the signal correctly. it did not show a speed on the data stream still.
so then i got out the multimeter. I checked to make sure i was getting voltage as each of the plugs at the end of the wire harness, and i was. I then checked the Ohms on each of the sensors, and they showed the same. so i am farly sure that the sensors are good, and that the wire connection from the ABS module to the sensors is still ok. (i did see a lot of post of chaffed wires, but i did not see that on my car)
is there a chance that the module is just not processing the data correctly? is there a way to check that? do i need a new ABS Mod?
Id agree, but for the fact that i plugged the wire-harness for the driver side wheel sensor, into the sensor that was installed in the passenger side. the passenger side was working properly. the thought was this would test the abs module, as everything else was working. it did not give a reading. is there a way to test just the module, or do i need to pull it out and send it in.
Yep, rusty back side of the hub and it cannot read it. They can get dirty and rust over time and cut into the sensor head sometimes (mine did it). Also when you install the sensors you can crack the heads if you dont clean the install hole. So watch that. Pull the wheel bearing and check the back side, clean it off and make sure the seal is not rusted out and causing issues on the read.
https://www.northamericanmotoring.co...-on-tight.html
ssoliman (07-02-2020)
