Yellow engine light, limp mode, codes ahoy!
Hi all. Got a 2013 Clubman here with about 70,000 miles. On the highway it started shuddering, displayed the half-yellow check-engine light, and would barely move.
Subsequent code check revealed P0300 and P0300 P. I've replaced the battery, spark plugs, and coils to no avail. I checked the fuel-rail pressure and it reads 60 PSI with a dial-type tire-pressure gauge (not the optimal tool, I realize); from that I conclude that it's probably not the fuel filter or fuel pump, although the filter is probably due for replacement.
Now a code check pulls all of these:
p0300 multiple cylinder misfire
p0302 cylinder #2 misfire
c0300 rear speed sensor malfunction
c0700 something MAF-related? Hard to find good reference on this
p0597 Thermostat Heater Control Circuit Open
I find it suspicious that all of these things are suddenly occurring at once; can an electrical disturbance cause spurious codes?
Anyway, I don't know what to try next. Advice appreciated!
My google search came up with:
C0300 = Fuel rail pressure sensor malfunction
C0700 = Engine oil temp sensor malfunction
A battery issue or other electrical issue can cause all sorts of problems on a Mini. It is good that you pulled all the OBD codes. But, you really should grab a Mini specific code reader to check for other manufacturer specific codes that might be stored. The Mini codes will help you narrow down the root cause of issues.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
ECSTuning (07-08-2020)
MINIesther
R60/R61 Stock Problems/Issues
04-18-2018 06:54 AM
U.S.A. Ranger
01-19-2013 02:19 PM
