2013 Coupe JCW - Help!
Hi all,
I have a 2013 Coupe JCW. I was going down rough driveway and a hit a bump pretty hard that also scraped the bottom the car. Immediately after this, the car will idle rough for a moment, then idle fine. If i accelerate, it sounds like something is out of alignment.
Do you know what the issue could be?
Thank you for the help.
No point speculating until you get underneath it with a flash light, if you stuck something solid (rock) it will be easy to find as there will be evidence of the damage, and if you are experiencing performance based issues, then look for the damage on the engine, and fuel tank and check fuel lines to see if ones squished.
