N18 crank but no start
Hello,
today i took a look at my friends 2011 mini cooper s. The car stopped running a few months back and the mechanic she took it to said that it needs a new engine. I figured id give it a go on my scanner anyway, so i plugged in my scanner and ran a diagnostic and here are the laundry list of relevant codes ive found:
A86E, E736, 9C59, ABEB, 931F, 931D, A0B6, 5E30, 5E31, A06C, 2D5A, 33FE, 2D55, 2D60, 2D54, 2C58, 9E31, 9C75, 9C90.
The codes range anywhere from a IHKA control unit fault, to low oil pressure, to uncontrollable VANOS gears and i don't really know where to start looking. The codes 2D55 and 2D54 arent giving me a good feeling.
If someone that is a bit more knowledgeable these codes could help would be much appreciated.
thank you,
Xavier
thank you,
Xavier
Use this site for code interpretation:
https://bmwfault.codes
2D54 and 2D55 are likely just the vanos solenoids. Pretty easy fix on those.
Some of the codes could be related to battery voltage being too low. If the car is still on the original battery, swap it out for a new one and go from there.
Nemick
02-02-2020 07:50 AM
