Big oil leak, possibly PVC membrane
Hello,
Today at a MINI rally after a fairly high engine run with a cab, huge smoke and smell of oil.
When I opened, I saw oil all over the top of the engine, on the hood, well everywhere in large quantities (N18 engine)
After wiping, oil level and checking for leaks while running the engine, I slowly hit the road at 3000 rpm max. 3km after that comes back, so immobilization of the vehicle.
We were initially thinking about the cylinder head cover gasket because I didn't change it on a timing chain remplacement, but when cranking the engine the oil didn't flow from there but to the PCV diaphragm cap.
My question is: Is it possible for so much oil to squirt and splash all over the engine when running at high revs if the diaphragm breaks? Or am I looking elsewhere too?
Thank you !!
Thank you !!
Hello,
Thank you !!
Thank you !!
That’s reassures me a little..! Do you think it’s possible as much oil leaks to this PCV membrane ? On an other forum somebody tells me « To get so much oil out, there is a loss of compression in the lower engine. One or more broken segments ». But I think an error code appears when I hit the road if it’s true ? I’m wrong ?
Tomorrow I´m to the auto garage to try to fix it and also change the cylinder head gasket cover seal.
Hello, thank for your reply !
Before you pull the head to change the gasket, run a compression test and see what you have across all 4. This might save you some trouble.
"too bad"?? I wish my french were as good as his english!
@@Yann Rul : Welcome to the forum! Please keep us posted how it turns out.
And for my English, I try to make my maximum...
