No headlights, low beam warning, tested good FRM
Low beam warning came on, lost both headlights when running. High beams do not work also. (diagonal down lines with exclamation point in light).
Can get lights to momentarily turn on by disconnected and reconnected headlight connectors while running, but they turn off in about 3 seconds, thus not fuse.
Was told likely FRM, sent to ECU Pro for testing and still have the problem once re-installed.
2011 mini cooper S. 104K miles.
dcwang3
01-25-2020 10:00 AM
