Bleeding ABS module
Bleeding ABS module
Hi all, the brake fluid reservoir ran dry during a brake bleeding fiasco. I bled the brakes twice more but still feel the pedal isn't quite right so suspect there may be fluid in the ABS module.
I don't have access to a diagnostic machine to bleed the ABS but did read that by engaging the ABS it opens up and then you can bleed as normal. Is this BS or does it actually work?If so would you have to bleed immediately or by opening does it hopefully push any air through to be bled normally?
Cheers...
Cheers...
Petkorazzi
09-20-2019 03:18 PM
Grahams315
12-11-2012 01:14 PM
