ScanGaugeII coolant temp reading - source?
Hi all...
I am tracking down the issue of a coolant fan that does not work.
I have read as much as I can on it and have tried numerous solutions...too many to list really.
my question here is does anyone know where does that ScanGaugeII get the reading for coolant temp?
I assume the ECU, but does that mean it comes from the coolant temp sensor?
basically, if my SCII reading is accurate, does that mean my coolant temp sensor should be working properly (sending correct info the the ECU, which SHOULD then send current to the coolant fans to turn on).
Thank you in advance!
jjcsnlynn,
Wish I were in your boat...or car in this case.
I do know the temp trigger numbers, but was trying to trouble shoot why mine is not coming on...
my question is where does that ScanGaugeII get the reading for coolant temp?
I assume the ECU, but does that mean it comes from the coolant temp sensor? if so, that will tell me at least that part is working and I can move on to something else....
