Error 9CC2 (AHL system)
Hello guys.
I hope I can find here some guidance to solve this issue
I have a MCS N18 from 11/2010. The car came with system AHL stock and it worked properly until 2 years ago when appeared an error 9CC (Stepping-motor controller (SMC), right signaling fault) related with AHL.
I "solved" the issue easily, with NCS Expert removing the $524 from VO. It is not a solution but the error was gone because I tricked the car saying AHL doesn't exist. In other words it is not a solution.
So yesterday I activated the VO $524 again and the error came again. I also tried a different thing: swap SCM module from the Left to the Right and vice-versa and afterwards coding/reset the modules and if the problem were from SMC the error should appear now on the Left side. But unfortunately the error continued in the Right side (same error) - 9CC2.
The steps I did to coding/reset SMC (left and right) were the following:
Open NCS
F1
F3
Select R56
Ok
Select CAS
Back
Process ecu
Select RSMC/LSMC
Change job ‘codierdaten’
Execute job
Change job ‘sg codieren’
Execute job
What I concluded here was the RSCM is in perfect conditions, and maybe the problem is from elsewhere. Any clue? Did you face it in the past?
Thank you in advance!
Open NCS
F1
F3
Select R56
Ok
Select CAS
Back
Process ecu
Select RSMC/LSMC
Execute job
Execute job
