Is heat required to remove knock sensor?
I mean, it shouldn't require heat by design. If a bolt is rusted or stuck heat can help, but I wouldn't expect to need heat with that particular bolt.
If I can trust my Bentley manual it's just a remove & replace job. The tightening torque spec is 20 NM (14.7 ft. lb) and it says "replace o-ring"
Completed the work, replacing the sensor from below the car. It had some type of lock-ite on the threads. I used the blue type to go back with. Thanks for the reminder to torque to spec, which is 14.7 ft lbs. Why haven't they invented sockets that are magnetic yet. What a pain trying to snake the bolt around stuff without it falling off the extension and socket 50 times. Grease was not heavy enough to hold it on the socket either.
