Code help
Thanks but how come I dont get any ABS light on dash. Also I did unplug my tach when I installed my boost guage but I disconnected the battery so it wouldn't effect anything. Do you think it still could have effected the steering angle sensor. The yellow triangle warning light started coming on after I did the boost guage. The wierd thing is the yellow triangle doesn't come on all the time now. Sometimes it's on then I shut the car off and it stays off.
Removing the tach caused it even though the battery was disconnected.
you need to have the stealer or a garage do it. My son is a mechanic and has a good scanner and it does this stuff. All the codes may be related to removing the tach. Interesting enough the right rear abs sensor also drives the speedometer and the tach is connected to the same module.
So strange because the boost and volt guages I installed were actually oem from mini and followed their directions and nowhere does it tell you you will have to have a recalibration done or codes cleared after doing the install which they know you'll be unplugging the tach. I wonder what software is needed to clear it. I have a handheld scan tool that can clear codes but can't recalibrate things. I dont think. It's the foxwell one. I appreciate the help.
Kitchenboy (05-07-2021)
Ok well I recalibrated my steering position sensor and cleared the codes with my foxwell nt510 elite and took it for a,drive. A few minutes later pulling out of a driveway the DSC light flashed a few times and went off then after maybe 10 minutes I came to a stop and when I turned the corner the light came on solid. Running the codes again now.
Big Dave
03-21-2006 10:08 PM
