2007 r56 p1515 / $07e
My daughter has been getting an inconsistent check engine light and the Schwaben is picking up P1515 / $07E. I can't seem to find where I put the shop manual, and I also can't seem to find a consistent answer as to what it means on the internet.
Anyone have access to what this code is referring to?
My Bentley guide says "Engine OFF timer plausibility"
Doing a search, "The DME detected an implausible instrument cluster and/or power module signal. CAN signal failure while the DME was operating at a range between 6 and 16 volts. CAN Bus lost communications. The system time (time pulse) is implausible relative to the DME’s"
