Front sway bar bushing size`
My front sway bar ('04 S) measures 21mm. It came with the "Sport Plus" suspension but I'm not sure that makes a difference on the sway bar. I want to replace the rubber bushings (with rubber) but the only bushings I can find are either 22.5mm or 24mm. Anyone else run into this issue before?
I just ordered some, after some research, I believe the stock (even with sport suspension) is 24mm for front. I don’t believe they changed year to year, but you should definitely check before you order. Are you the original owner, if not, maybe the PO swapped it out, 21 is an odd size.
https://new.minimania.com/part/NMS76...m-Gen1-R50-r53
Suspension so, what size is the front swaybar bushings?
astroBlackMetallic_Mini
Suspension
05-12-2013 05:11 PM
